Rimington Steel
So I downloaded Noled on my Vibrant, but it doesn't seem to be working and I can't find the app on my apps lsit. Does it need to be activated or something that I am missing?
all you have to do it apply it to one of your screens.
- Long press the screen
- Hit widgets
- Scroll down to NoLED and click it. It should be on one of your screens
- If the ball is red just touch it until it's green. now it's active.
Whenever u see the LED click the home button not the power button. The power button make it appear/re-appear.
Hopes this helps.
I'm just here to help. U can thank me by hitting my thanks button. Thanks!
You can't change the colors but hopefully this helps you out:Soooooo can u answer my question
Question : How do i set it so i have different colors to flash etc miss call pink, text msg blue?
Kinda off topic but why does my notification vibrates when my settings for vibrate is off?
Try resetting your phone. If all else fails hard reset. But you'll lose data doing that.
How do i soft reset?
I notice when i turn off the vibration intensity its not an issues.
