getting notes from phone to computer???
  • Start date Start date
A
Android Question
Guest
okay so my issue is that i have notes on my sony xperia z i desperately need to see but my phone screen is smashed, and ive been searching through files on my computer to find them but cant, im aware there is apps for this problem but can i use them to get the notes of my phone if i cant use the phone??
all my work hours are on my phone and i wont get paid if i cant show the hours ive done!! nightmare please help
Have you tried to search them out using the computer's OS. ie. Windows or Mac
One problem is the app you saved the notes with would have to put the notes in a format that the computer can read and in a place the computer can access.
If you kept your note with evernote then you could have got them from the windows app they have. Thats one solution. I not following how you stored the files and where. Cant you hookup your phone to your PC and get your files? Dont you have the USB drivers installed and working to search the phone? Or a sony program you use to keep backups on your PC?
