Help Getting "Unexpected Error" using Quick Memo
MiamiJeff
Hello, I have my LG Venice on Boost now approx 1 week. I have been unable to have the Quick Memo / Screen Capture feature work for me.
I get this error when I try and save the screen shot to my gallery - "CANNOT SAVE DUE TO UNEXPECTED ERROR. PLEASE TRY AGAIN LATER"
I can draw on the screen .. erase the writing on the screen but not save anything... I just get the error mentioned above..
anyone have any ideas on a fix or have the same problem ?
Yes I can take photos with no problem and they are all saved into the Gallery.
I also noticed the same error message when trying to use the "Memo Feature" also..
Did you try going into the app settings and clearing the cache and things for that app? I just tried it and it works fine for me.
My Cache is cleared..and Error Still apears.. probably contacting Boost this Monday.. Nothing on my SD card yet.. im waiting on a new 32GB SD Card ..should be here this week which I am swapping out the 2gb card in it now.
Can you take pictures? Almost sounds like a SD card problem.
Well you were correct ! Thank You for the advice.. I didnt remove the current 2GB card that came with the phone when I posted this thread.. my 32GB arrived today .. I tool out the old 2GB.. inserted the 32GB.. and let it boot up and now the Quick Memo is working like it should..! I am glad to have this small problem rectified..
Thanks for your advice.. ! dhrandy Hope you got your FB photos over to your contacts.. !
That's good. I also received and installed my 32gb card today and it works great. I was having problem with my 16 gb that I took from my Transform Ultra. It was going into read only mode. I think it wasn't working because it was a lower class card.
I downloaded a Facebook sync app that syncs the photos, so that's solved.
You should also try the official Swype app if you use the built in Swype. It's much better.
