Root Getting Update failed message when using Ascend updater from Metro PCS Store
I have another problem, I flashed my phone back to stock and planned on updating it with the ascend updater on the app store with Metro, and now it is dying on updating the firmware. I cannot return the phone, have no money to pay for a new one and don't want to, there has to be a work around for this.
I had not re-rooted the phone after flashing it back to stock. Used the files here for the flashing, it worked fine and then I had updated it this morning just fine. I erased a file with TB by accident and I reflashed back to stock to fix it, thinking I would do that and then the ascend update again, and now I am getting this error. Have no idea what is going on!!
Why not flash playful mod? Its 2.2 rooted deodexed and mostly cleaned of metro.
I had cm7 on my phone, had gps issues and the headset was not working for handsfree driving. I wanted to go back to the Metropcs 2.2 and had it done this morning, but I reinstalled the factory and now I am getting this error.
playful mod have gps issues or messaging issues? I need something that works just as well as the metro 2.2.2.:D
I've never used it because it it's only for Metro, but it is just the Metro ROM, rooted and de bloated by default, so it *should* work even better than stock. It's basically like a 2.2 version of Icarus.
Afaik it has no issues (I haven't used the ascend in a couple months.
Ok, sounds like a plan for me. Now I have a new sd card, 16 gb instead of the 4 that came with the phone, before I start everything, how do I change to that card and use that now, I know I have to partition it, that is in CWM correct?? Just wanted to make sure!
Ok, I have installed this, looks just like the 2.2.2 but I am having 1 problem, seems that rom manager is trying to update from the market, but I keep getting an error, package file was not signed correctly, uninstall the previous app and try again.
How do I do that, I cannot find the app to uninstall it, when I look in my applications in setting, is shows up, but when I try to uninstall it, I am not given that option.
Help!! I do not want to keep getting this error.
You don't NEED the metro wifi app, your wifi will work perfectly without it. It just helps you connect to some of metro's wifis that they have close to their stores.
^What he said. the app is worthless in my opinion. Basically only advantage is it shows you a map of networks that are documented (meaning not all will show like my neighbors dont) in the area. Besides that its pretty much worthless in my book
I would try to clear cache/data for ROM Manager, in Menu -> Settings -> Applications ->Manage Aplications, then run "Fix Permissions". Otherwise, if you have Root Explorer or TiBU, you should be able to uninstall that way.
titu will let you uninstall anything, also Root explorer will also.
