so since this update I have a number of problems. if i set an alarm or basically go into any option menu with a checkbox, tapping on it makes no visibile difference, but it will turn the option on or off. I know cause the alarm will go off if i tap it, but the checkbox doesn't change.
and also, this is probably simple, but i can't seem to get a google search to work simply by typing on the slider. i used to be able to, now i ha ve to go on the internet and search some old fashioned way
sprint htc evo shift 3g at best.
