Root Gingerbread Color
GandalfTehGray
Android Expert
Any one know the Droid X Gingerbread Color code for notification bar? would like to try to line up with widgetsoid and find a clock skin that fits GB.
#A4C639
they have that as the official android color on other sites, you can always google search it, there is no real easy way to determine this, well at least i cant at work, you can find out using gimp by using color picker to locate the actual color
PM fabolous or bouchigo and ask them to look in there xml files to locate the color sequence
#A4C639 is for the standard AOSP Android green.
The DX Gingerblur notification bar is a navy blue gradient.
#1d2d3d is taken from the middle of the gradient.
