Root Gingerbread & Pandora Reboot Issue
danmcq
Anyone else have issues with Pandora rebooting? I've had this issue with almost every version of GB that has leaked so far (currently on .595).
It's an odd issue. It only occurs when I am driving, and have Pandora running with my DX plugged into the aux jack of my car.
I used to have this issue all the time, except instead of rebooting it would activate redial. Very annoying.
I don't know what I did to fix it. I just probably upgraded to a new leaked ROM and then the issue went away.
I was having this problem on all the leaks except .591(5). It would play the first song then right before it ended my phone would crap out and reboot.
This may be a little off topic but I had this issue using poweramp. Whenever it was connected to my cars aux jack it would turn off in a minute then my phone would reboot. Turns out it was just a matter of changing the settings within the app to not turn the display off. Once i did that I had no problems with it again. Check to see if there is a similar setting in Pandora for the car dock/ aux jack.
i run pandora all day at work on my phone and it shuts its self down after so many hours (playing or paused) and then i have to reboot to get it going again.
side note i am on .340 so idk if this will be the case with yours just a thought.
