Home button doesn't work but back works fine.
Forgot to mention this, but when you're ready to give flashing a try, READ THE INSTRUCTIONS!!! When done, go back and READ THE INSTRUCTIONS AGAIN!!!! Repeat until you fully understand what you're doing.
At this point, I am undecided whether or not to go to the telus version if/when it comes out. CM7 feels good on this phone and I don't miss any of the Samsung Apps.
My only complaint with the Telus Fascinate(SGH-T959D) is it's obscurity. That made the search for appropriate ROMs and upgrades a big headache.
The T959 Vibrant or the i9000 Vibrant?
ha. Yeah, I don't think I've ever used any of the Samsung Apps. Hopefully when Telus releases Gingerbread to the SGS a fully functional ROM will come out that doesn't leave any of the hardware buttons out. I'm sure the missing home button probably isn't that big of a big deal, but I'm just anal like that. heh.
I felt the same way. Just got tired of waiting so I decided to start experimenting. The first time wasn't that impressive so the phone went back to stock. Meanwhile, the cm7 team was constantly publishing updates and fixes. When I tried again a few weeks later, it was a good experience. A few nightly updates later, near perfect.
One lesson learned was to always make sure the battery was fully charged. I had a couple times when the phone either bricked or the files corrupted. Each time it was because the battery charge had dropped too low.
Flashing a ROM for the first time is a very daunting task(READ THE INSTRUCTIONS). It gets easy once you've done it a couple times. If possible phone downtime is a serious problem, don't try flashing a ROM. The first time I did this, I went in with the attitude that if the phone bricked, I would just go buy a new Nexus S. If that had happened, the Fascinate would have been sent for warranty then used to experiments after it was returned...a frankenphone.
As for the Vibrant comment, since the T959D is a fairly obscure phone, I did a lot of research about the phones and various ROMS before I made a move. ROMS for either the T-Mobile Vibrant or a generic i9000 should work. I chose the i9000 and it worked...period. Simple?
Flashing a ROM for the first time is scary, especially if it doesn't work right. I was ready to head to the store and buy a Nexus S when mine went wrong the first time.
Just for fun, I just tried flashing the cm7 ROM for the T959 T-Mobile Vibrant onto the Fascinate. So far, so good and the buttons all work correctly.
Are you going from stock to stock+voodoo? If so just download SGS Kernel Flasher from the market place, back up your current kernel. Copy the Kernel you wish to copy to the root folder of the phone, find it with SGS Flasher...wait 10 minutes. Done.
My Fascinate is still under full warranty with Telus and I am reluctant try a custom ROM which renders some controls or functions inoperable. As for the ROM apps as well their functionality is important to me. Yes I don't use them all and most are bloatware. This smartphone has a large internal memory and even with added apps I have tons free still so its not a concern.This is why many of us have found a way to upgrade to Gingerbread(2.3.4) on our own with the use of custom ROMs. We got tired of waiting. At this point when GB finally comes out for the T959D, I will probably pass so I can avoid the Samsung bloatware.
As for being slow to update, the Sony Xperia 10 just got Eclair(2.1) a week or so ago.
DarkyROM 10.1 runs very nicely on both my T959D handsets. No issues whatsoever.
