Nurseferatu
Member
I'm a novice--I was wary of rooting my phone, but I was tired of waiting for Gingerbread. When I found out the stock OTA file was available, I followed trparky's excellent tips and am now running Gingerbread 2.3.6.
I decided to put all the detailed steps in one place for other newbies like me.
(Today trparky said my instructions were good enough to quote on his page. I regard that as an endorsement.)
Disclaimer: This worked for ME. But your phone has different stuff on it and possibly different configurations. If you do this, something COULD happen to brick your phone. Only do this if you are prepared to take responsibility for whatever happens.
Here's how I did it.
Before you begin
GET THE NEW GINGERBREAD FILE AND PUT IT ON YOUR CHARGE'S SD CARD
1. On your PC, go here and follow the link to download the new Gingerbread file:
GB OTA manual update.zip-leaked! - xda-developers
2. Rename the file to update.zip. Don't unzip it.
3. Connect your Charge to your PC and open the SD card.
4. Move the update.zip file to the SD card but make sure it isn't any of the folders.
START THE INSTALLATION
1. Disconnect your phone from the PC and power it down. Don't connect it to AC power (my Charge kept wanting to recharge).
2. Simultaneously press and hold Volume Up rocker and Home button. As soon as you you have them down securely, press Power at the same time.
3. When SAMSUNG appears, continue to hold Volume Up rocker and Home button but let go of the Power button.
4. A new screen appears with a little menu. You can let go of the Volume and Home buttons.
5. In the menu, select "apply sdcard:update.zip." To move to the selection, use the Volume rocker (up or down) to highlight apply sdcard:update.zip and then press the Home button to confirm your selection (it's like pressing Enter).
Installation starts, indicated by a progress bar. Be patient. DO NOT touch the phone because anything you do at this point could brick it. It took my charge about 25 minutes; your mileage may vary.
If the installation is successful, the Charge reboots on its own.
CONFIRM INSTALLATION
To confirm installation, go to Menu > Settings > About Phone and look for 2.3.6 in the Firmware Version entry. Beauty!
I'm finding that everything is more wonderful, although the Charge still can't microwave my coffee.
ALL PRAISE to trparky!
Before you begin
I used my PC to put the update file on the SD card in my Charge. If you don't know how use your PC to open your Charge's SD card, this won't work for you.
- Make sure you have a fully-charged bat
