While using navigation, I made a phone call and upon returning to navigation (using Satellite view) the view had changed from a spring like view to a fall view the lush green had turned to a more fall like shade. Just curious if anyone else has noticed this?
well, you were in a different location when the call ended, so you would have appeared to 'jump' from one location to another with different greenery, etc.
That probably depends on when Google's sources took photos of the location. They are all overlayed with each other and it's possible that one area was taken in spring while an adjacent one was taken in fall.
Look in Google maps on a web browser (on a PC) in the same areas and see if that is the case.
Its a color glitch I can be stationary and it does the same thing. If you have this ROM just turn navigation on and then go to phone dialer etc. And then reopen navigation. When I do this the view is all in brownish shade.
