Help Glass slightly raised at bottom
Lowey5
Description says it all but I have noticed the bottom part of my glass screen to be "up" and raised, I can push it back down but it comes back.
Should it be glued down? has it come loose? is this a known fault?
Phone is about 6 months old, never been dropped and in a genuine HTC case.
Exactly the same with mine, mate. Only notice it under certain ambient light conditions though. Thought mine might have been exacerbated by using a Mugen 1800 mAh battery which is ever, ever so slighly thicker although it slides easily into the battery holder.
Ah, well theres a thing, I have that battery too, wonder if its that, I have had the larger the battery from day one.
Hi,
Since I updated to 2.3.5 and sense 3.0 I decided to go back to origional stock battery as I read that the new version extends battery life.
I have been using it for 5 days now and the battery life is very good, the reason I also write it here is that since going back to the stock battery my screen issue has gone away and the glass gone back into place.
The larger capacity battery was good but clearly it physically larger too!!!
