Root Global Quadrant rank
I guess it depends on which Launcher your using....I was using Go Launcher and my scores was 1089 and I switched to zeam and my score went up to 1136...dont know about adw or others yet....
im running GB with inigo's bobrom and adw standalone and i got 1084 overall but every now and then it will go to 1200 depending on what apps are running at that time
IDK what this all means so i got curious
overall rank 1806
model rank 8
overall performance mark 828
So am I cool :cool:
or not? :o
My overall performance rank is 896 and my overall rank is 1736
So is that you thats #1 in model rank?
I'm using an app called Quadrant Standard, I'm wonder if a different app may give different readings. Just curious....
So this is what I figured out while testing two different Quadrants.
Quadrant Standard gives me only the overall benchmark rank between 1127 and 1138.
Global Quadrant rank gives me an overall performance mark of 828 and an overall rank of 1806.
So what are the real numbers that we can trust?
The one that rates you better :D
I guess its all just a number game. I will say this, performance can be seen with CTmod 2.1 and 2.2. That is the bottom line :).
I just got an 895, which is good enough for 3rd in the model rankings right now. Running CTMod 2.1 though, not the newest (yet).
Edit: Tried again, this time in airplane mode, and was able to break 900- a 903, good enough for 1st place (for now). Here's a screenshot:
I agree, but its still something fun to do with the phone. I did it in airplane mode and got a score of 918 which would be a strong 1st place in model. But I forgot to turn off airplane when i tried to submit my score so its not there. But i did get a screen shots for it. Its obvious that its not to accurate when you can get a 820 something then run it again right away and get over 900. So really.... what are you to belive??
Im sure there are prevails here that can out perform my phone but have a lower score than mine, but its all in fun just to test it out.
