Help Gmail Account problems.
bp08
Hey guys,
So ever since I got this phone on the 15th, I haven't been able to get my Gmail to receive messages unless I do it manually (go into the app and refresh myself) Although the Email app works perfectly fine with notifications instantly. All of my settings looks correct, it just seems like it isn't pushing them automatically.
Anyone else having this problem?
do this.. go to settings, accounts & sync, then the Gmail account. Set it to SYNC your emails. I didnt have it "sync" cause i misunderstood what it meant. Try having it "set to sync"
thank you .. for some reason everything was checked aside from sync emails (for some odd reason) . Does anyone know how much battery the phone uses when the data sync option is enabled and set to 'push' compared to if this option is disabled?
