stmartin84
For some reason whenever I send an email or reply to an email it automatically adds the email address to my contacts folder. Not sure what's going on, could someone assist?
Log into Gmail and make sure all the contacts you want to sync are under "My Contacts". Then using the Eris: People>Groups (3 heads on the bottom)>Menu>Sync Groups. Uncheck "Sync all contacts". Whenever Gmail creates a contact it will be in "All Contacts" which will no longer sync.
This does not work on my Eris. When I go to People>Groups>Menu, there is no option to Sync Groups. There are only two menu options: Add A Group and Delete Group. I haven't done a factory reset of my phone ever, or anything like that, since I bought it in January. Why wouldn't I see that menu option like you guys?
