Help Gmail 'labels' not loading
ziggy1024
Member
I use the Gmail app for mail & until yesterday it worked perfectly. Now, when I try to view messages under any of my 'label's (Menu\Go to labels\select one!) it just shows 'Loading conversations...', and doesn't ever actually load anything!
I hadn't changed any of the sync times or any other settings within the app, but have since tried! I've cleared cache, & cleared data for the app. I've uninstalled the app updates and re-installed. I tried setting up the standard mail app & that could see everything fine. Likewise, accessing gmail through the web browser works as usual.
Standard 2.2 Desire, non-rooted.
Any ideas?! :confused:
Really want to avoid trying a factory reset, as I can see that being a bit of a pain WRT getting things back to how they are...
Cheers!
Solved! If anyone's interested, 'Saymyname' was at fault. No longer set to read my email and it now works fine... Installed that fairly recently, but I guess I must have switched the email option on a few days ago and not noticed a problem straight away! :)
