So I was on v3 leak and everything on my phone was working fine, I then was going to try to root mine, and upgraded to the RUU per the instructions, after many attempts I was not able to root so I gave up for a while. But since upgrading to RUU I've noticed that my gmail is not automatically syncing. I've checked all settings, and also following clearing the gmail cache, and turning off HTTPS on gmail, nothing seams to work. I can get activesync to push to my phone fine, but not gmail. I'm wondering if this is a RUU issue or some issue with my phone or something I'm overlooking. I thought at first it was the extensions in Chrome, but ruled that out by disabling those. If anyone else has had this issue and knows something I could try I would be appreciative, otherwise can I go back to leak 3? and if so does anyone have the link anymore?
Thanks in advance.
Jason
Thanks in advance.
Jason
