L -l3x- Member Aug 7, 2011 #1 I can't seem to change my notification sound in Gmail. Is anyone having the same issue? I am running 2.3.5 for the Gmail version.
V425 Android Enthusiast Aug 8, 2011 #2 -l3x- said: I can't seem to change my notification sound in Gmail. Is anyone having the same issue? I am running 2.3.5 for the Gmail version. Click to expand... Do you mean that you can't find where to change the setting or that you've set it for sound but it doesn't work?
L -l3x- Member Aug 11, 2011 #3 I fixed it. I just had to wipe data, cache, and dalvik and then re flashed.
D DizzyThermal Lurker Aug 15, 2011 #4 Hey guys, I'm not sure why, but I can't seem to find the Notification Settings in Gmail 2.3.5.. Anyone know where they are? I can't seem to change me Notification sound Thanks in advance -DizzyThermal
