Help Gmail notification
So I have in the past changed my gmail notification, but now I cannot seem to figure out how I did it before. I go to gmail/menu/more/settings/and I hit my account under the account settings and I cannot find where I changed my notification ringtone. It is driving me crazy did they change this? All the threads on this explains the same process that I just explained so I have gotten no where so far.
You're in the right place, but there are still a few additional steps. When you select the account you wish to set up/change a notification, you will need to scroll down to the bottom of the screen and select labels to notify.
Then you select the ringtone you would like to use for the inbox.
