Help Gmail problem
gaafar
i have a account in Gmail but every time am trying to signin the apps spend some minutes, after that shows to me this msg " can't establish a reliable data connection to the server. " i cannot use any apps or market.
Do you have a connection to the internet?
If you are connected via wifi, check that you are getting an internet connection on your computer via the wifi router
I had the same problem only 2 days ago. I ended up having to factory reset, though I'd try the above options before resorting to that.
