breynolds007
I'm an Android OG and I've had this phone for a little over 5 months. I
I just recently found out why most high end phones are so big. Wired just did a piece on how the Iphone will be getting bigger in the near future. And it is because the LTE 4G antenna and chipset is large and you will have to also get a large battery to feed the chipset.
I will assume that we won't see high end phones get smarter until 4G is every where and they can stop putting CDMA chips and antennas in it. Or LTE advances.
"Answering phone calls-Recently, I
The only thing I
Are you talking about T9 dialers? There are lots of 3rd party dialer apps in the market, Dialer One is a great one.
https://play.google.com/store/apps/...=W251bGwsMSwxLDEwOSwia3oubWVrLkRpYWxlck9uZSJd
That might work...if a phone number I don't have saved calls me, I'd like to be able to start typing the # in the dialer and it show the #'s history (If its been called/received before). It seems the stock dialer only searches your contacts.
