Help gnex being a little issuey with the bluetooth
NexusTootsie
after turning on, pairing, trying every which way to pair shut off shut on etc etc, my bluetooth device does not pick up my music from my nexus, neither with the google music app nor the Tunein Radio app. Both of these apps work perfectly well with my eee transformer tablet and the same Rocketfish BT device.
thoughts?
im sure you probably have this checked, but on your phone bluetooth menu in settings.. go into the device that you paired with settings.. Inside you can check to see if you have phone audio and media audio checked
I'm giving this some thought. There's a backup app - my backup pro - which isn't too expensive and can be set to schedule regular backups. I think I'd like that..a relatively painless way to backup and/or reset.
I'll tell you, my thinking is it doesn't thrill me to wipe it clean. I don't want a device that needs to be wiped away when I've only put maybe 20 or so apps on it, if that and have only just started to do music/image storage and editing on. If I have to reset and possibly go through this again, I might as well bring the little guy back to bestbuy and get a fresh one.
