Hi, I've downloaded the GO Launcher and replace the standard on that came with the Infuse. My question is does the GO Launcher waste my system resources? I notice somethings running a bit slower after the install and there's a bit of lag. I've put on a ton more apps too since installing the launcher so it's hard to tell if it's the GO or something else. Thanks for your time.
