I'm having trouble with the app icon size. I initially set the icon size really small, but now I want them back to the default size and it's just not letting me do that. And yes, I go to preferences>visual settings>icons>icon size and then press default size, but nothing happens. It just goes straight back to the custom size. Anyone know how to fix this??
Edit: Okay FINALLY I figured out the problem. Taken from the xda-developers forum:
Here's the caveat: it seems that if you make a settings change above, and hit the 'Back' button at the top, the change won't be applied. Ditto if you hit the 'n' button. Use the arrow back button on the status bar at bottom, and then the change should stick.
Just in case anyone else was having this problem.
