I really need some help, trying to turn on the popup quick menu, because right now I just get the options to replace/rename/delete with a long press, and not resize anything. But can't find the quick popup menu tab to enable this. It is supposed to be under the "operations" tab/folder, but I can't locate "operations" tab anywhere.
Under preferences, the gesture settings are their own tab and not under operations. It's driving me crazy? What am I doing wrong??
I'm posting this here because I wonder if it's a commando specific issue??
Thanks!
Thanks!
