Go Launcher HD
idic
Hi - just tried out the new beta of Go Launcher HD for tablets Android 3.0+ but I couldn't find a way of switching between launchers. Pressing the Home button didn't bring up an options list like it does on a phone, and Manage Applications / Clear Defaults for the Go Launcher HD app was greyed out so no luck there either. I've now uninstalled, until it goes through a few more updates, as I really want to use this as it gives ICS-style folders for my Honeycomb UK 3G Xoom which probably won't see ICS for a little while yet... But now home screen widgets aren't updating. I'll try a reboot, but if anyone knows how to switch between launchers that would be a great help as it would be good to use them both side by side for the time being...
Thanks.
Thanks - this supports changing between them via a notification toggle, but no way to set the default home...did you find this too? Hopefully later versions of the beta will fix this...
