Root Go Launcher Question
jacribb
I installed Go Launcher EX today. There is an icon on the bottom that looks like some form of a messing icon. When I tap it it says "this application is not installed". What application is that for?
its supposed to be the stock messaging app. If you removed it, then its not there. Long press on it and replace it with your texting app of choice along with icon of the theme you are using
