Help GO Launcher
T_VASS
Member
I downloaded GO Launcher last night and im really starting to like it but i was wondering when i hit my home button it takes me back to sense, is there a way i can set it to use Go Launcher and if so is it easy to go back to sense?
When you hit the home button it should give you a pop up that says go launcher and sense. At the bottom there should be a set default. Jut set it to go launcher.
After doing what glidewells said, if you want to go back to sense, you can change the setting by:
at the home screen, hit menu - settings - applications, scroll down and click on Go Launcher, then hit the clear defaults button
From there, when you hit the home button, the option to choose between Go Launcher and Sense will pop back up again.
