Emmaushornet33
Does anybody else have a problem that every so often when you go into your applications your phone takes foreveeeerrrr to load them or just it seems as if it slows down your entire phone?
I did have GO Launcher with the Phone Candy GO Theme on my phone and noticed the samething. It lagged bad to say the least.So I just switched back to ADW EX
I was using launcher pro and it was really smooth when I installed it but months later it kept freezing and crashing my phone. I'm also using 360 launcher and it works really good. Also using Puffin free to browse the web and it's fast and responsive!
metoo, its worst on zvc than on zvd, i dont want to change launcher because i have the iphone theme and golauncher themes every icon even if the theme doest have a custom icon for all the apps installed. hopefully go launcher fixes it.
j/k
