PhoneMan93
Is this not supported on the Galaxy Prevail??
Thanks! I thought I should post my findings on Go Locker. I felt it was kinda silly to make Go Locker require Go Launcher, some of the people who commented in the Go Locker market page felt the same way. Hopefully the devs will change this soon.:O fancy seeing you here!
just in case anyone doesnt know this man is the one who made the shabbymod bootanimation![]()
go locker IS suported by the galaxy prevail. u must install through the go store. (menu> go store> go locker) im currently using the '4 key' theme works flawlessly. but isnt customizable. you cant change the appearance through any settings
the link takes me to market ans says my device is not compatible with this item...
That's strange... I went directly to the Go store this morning and downloaded and installed the Sense locker.
i was looking at this app today and then i saw this post. i couldnt download it because it was not compatible with my phone according to the android market. the go store only takes you to the android market. to get it just use the link posted by Lordvincent 90. download it to your computer and then pass it to your sd card and install it.
if you are running shabbymod, he included download crutch. which lets u download any file reguardless type. you can download directly to your sd card, open it in file explorer and install.I looked into this yesterday, you have to have Go Launcher EX in order to use Go Locker. Currently, It won't work with any other launcher.
The link for Go Locker is dead and won't work.
