Help Go SMS Pro help required please?
GaryBC
I've tried contacting the developers but am getting no answer - maybe someone out there has an answer?
Well, two answers actually!
1) Having saved a series of text conversations into their own folders I'd like to be able to access them from my pc. I plug my phone in and mount it as a disc drive but cannot find them. I'd like to be able to copy the conversations into a Word document so as to reconstruct them (when saved to a folder each conversation is saved as a series of separate texts).
2) Is it possible, after opening and reading a text, to mark it as "unread" (like you can with an e-mail)? If I don't answer a text straight away I have a tendency to forget! If I could re-mark it I'd be reminded to answer it!
Thanks,
Gary
Have you tried any of the sms back up apps? They save messages to your sd in various formats. I'm not sure if you can filter conversations or whether you just get all your messages in chronological order.
It's worth a try, ta. Any in particular?
