Help Go Sms Pro
pbf98
Android Expert
I really like go sms pro, but I have run into an issue with it, and I am not sure how to fix it.
The problem is it will not send messages that is more than 1 page long.
With my the regular sms messaging app that is originally on the phone I notice that after you type 160 characters ( a whole page) it converts it into a mms message. With Go Sms Pro, it does not convert the message into mms, and that is what i believe the problem is, because when I go to messaging and go to the message and resend it it converts it into mms and sends right away with no problem.
Does anyone else have this issue and know any possible solution?
Thanks
Hope it's ok to post this here, but he "subject" of the thread isn't specific to any particular Go SMS issue....
I'm wondering if it's possible to set SMS ringtones to individual contacts. So one ringtone to one contact, another ringtone to another contact, etc. I googled this, and I read vague references that Go SMS can do this, but I can't get more info about it. Plus I can't find any settings in the app to enable this.
Thanks for any help. :)
Settings -> individual settings ... then just add the contacts you want to have individual ringtones. And set their tones
Thanks! But what a tease... you can only choose between Default, System, Current, and Music. The first 3 are the same tone. Too bad you can't choose from the many available on the phone. Maybe this is a MIUI bug?
oh god i just wasted 5 dollars in texting.............any free texting apps?
Textplus doesnt seem to work.
Heywire doesnt seem to work either.
