D
Deleted User
Guest
My mms tone rings twice when i receive a msg. The sms tone rings correctly, only once. I sure could use some help with this. Thanks
On Go Sms, in settings, right at the bottom in red writing, important tips, theres an option to make Go Sms work independantly of the stock "messanger" app ("stock sms uninstalled").
Try checking that, go to phone settings, app' manager, ALL, Messanger, then tap disable. See if that helps man.
I dont use MMS so its kinda a guess but it was only quite recently i found that hidden setting in Go Sms... if you disable stock "messaging" app without doing that, you wont recieve txts :thumbup:
Sorry, but that didn't work. Maybe it's my wife's iPhone that i'm using.LOL It doesn't play nice with my SGSIII. Thanks.
P.S. Do you know of any EMAIL apps that allow outgoing sounds, like go sms pro does?
Actualy any sound youre using, be it a sound recording or whatever should have "share" function (3 dots joined up with straight lines in a triangle) or share function when u press menu then select the email app youre using i think?
After a few days, GoSMS Pro screwed up my Google Sync. I had to uninstall it.![]()
Ouch. In what way mate?
Havent heard of that before..
Im usin a TW based 4.1.2 rom n everythings cool but we're on different devices man
