tonyguy2000
Member
After upgrading to Jellybean I did a factory reset from the settings thinking it would go back to ICS but I still had jellybean. What do I need to do to go back to ICS? Thanks. Just doing comparisons on 2 galaxy notes. Thanks.
What was the solution
Installing Flash Player manually, I bet.
How do u do that.? Root? Doesn't dolphins have flash in it
I installed your flash file, but it does not work on my n8010 with jb 4.1.1 - any ideas why. I tried to log into channel 4 website 4OD said need to update your flash player...... mine does not seem to work at all.
Cheers
