Root Going back to stock-best option?
when you sbf your completely stock, when you rom and flash back to stock, you still have roms stored as a save point so your not entirely 100% stock, that and your still rooted, if you sbf your not rooted, and there are no traces of current roms installed
Got it. So sbf is probrbably the best bet. Then I just get all my rooting aps, back and I am good. Should I backup and then format my sd card as well?
That worked nicely!
One question, I reactivated, etc. But it still knew my wifi settings? Are those stored on the sd card?
i think it may remember it not 100% sure on it though, but i guess its possible, i havent had the need to sbf in a while so i dont really know exactly
did you flash back to stock???
Yeah. Went ok. Rebooted, saw the custom boot animation and it stuck there. Did a battery pull, wiped cache and hard reset then rebooted and reactivated. Had the same wallpaper I had before and the wifi settings are all there-passwords, etc.
I'm pretty sure I read somewhere that google stores that info with your account as well. Don't quote me on it though. I just remember reading that somewhere. I don't even know if the source was credible. :p
Makes sense. Google is big brother! :eek:
Maybe he has the settings in privacy set to back up everything to Google? I always turn that setting off before activating my phone.
I do. I didn't realize it's for wifi, etc. But it makes it so much easier than plugging back in 10 passwords.
