going crazy
Welcome to Android Forums, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device( Android Phones - Android Forums ) and your Carrier ( Android Carriers - Android Forums ).
For Tablets check this section out, ( Android Tablets & MIDs - Android Forums )
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
What type of device do you have ??
You can download a version here, http://forum.xda-developers.com/showthread.php?t=1582422
I don't know how to download google play store app
Hello and welcome aboard. If your device isn't compatible _ you won't be able to download it onto the device.
Usually the Play Store app should already be preinstalled on the device - anyway, Download this:
[Updated x2] Download: Google Play Store (Formerly Android Market) v3.5.15 APK With A New Tabbed My Apps Interface, New Review Features, And More
And enable Unknown Sources if you haven't already. It'll install the new market.
