Root Going from CM7 to Apex 2.0
xRooness
So I admit, I'm fairly noob at this. ;p
I have a basic understanding of what I'm doing, however a friend of mine flashed my last two roms, and now I'm on my own. So I wanna make sure I'm doing things right before moving on.
I've done a fair bit of research, though, I can't seem to find any of my answers.
I'm currently running:
Rom: CyanogenMod-7-09012011-NIGHTLY-DROIDX
Android Version: 2.3.5
Baseband version: BP_C_01.09.07P
Kernal Version: 2.6.32.9-g5562e1 w30471@il93lnxdroid8 #1
I'm not exactly sure what the process is though to go from CM7 to Apex 2.0 (RC4) though. I assume I need to flash to stock, then move upto Apex 2.0 (RC4).
So, from my understanding, my first step would be to follow http://androidforums.com/droid-x-al...ad-602-sbf-root-process-updated-9-9-11-a.html
Then flash a new Baseband / Kernal to match Apex 2.0 (RC4) requirements, then flash the rom. However, I can't find those files.
Any help would be appreciated.
If you sbf to .602, it seems to me that your baseband and radio will already have been upgraded. Someone correct me if I'm wrong.
Yea, was kinda thinking that as I started to get ready to flash .602. - So that'd make alot of sense. Giving it a go now. Hoping for the best.
are you on the gb kernel cm7? the one by rev numbers? i havent flashed it in a while so i wouldnt know what it says
if your on the nightlies from rom manager, an sbf to .602 is needed
Mm, SBFing to .602 solved all those issues. However, when I flashed Rom Manager and flashed Clockwork recovery, it failed when I flashed it due to a bad wifi connection. - Finnaly got it to flash, however now it won't actaully boot into CWR. Any ideas?
