Root going over 1.6 worth it?
Just a thought.. is overclocking high really worth it or are you just killing battery unnecessaryly? Thanks
Well that depends on like are you running a game that requires alot of cpu, if not than your killing the battery a little more faster than stock, but at 1.2ghz you will be fine and also you will notice that it fast at 1.2 just like 1.6 but with less battery drain. Plus if you have one of those phones that likes to overheat when it's hot i wouldn't recommend going over 1.2ghz.
No its not worth it. The battery consumption ratio is no where near worth it. I guess it would be cool to OC for games or whatever but not for a daily use phone. I underclock mine to 700 and its as smooth as silk for daily use.
wow it is, i see no huge difference really. just know im saving a lot more power. just all depends on me as the user though. thanks fuzmaster <3 lol
You are welcome sir
