Root gold card failure
Tried the psas looked a bit complicated but will try that qmat link tommorow , I'm in the pub at the moment but cheers for helping
I just installed PSAS (I assume you mean the other one has a virus, because PSAS showed up clean for me) and it's very easy to use.
- Just install the free version, and then open it.
- Click Cryptoanalysis Tools at the top and pick Crypto Toolbox.
- Copy and paste the code you have into the very bottom box and press reverse string.
- Job done :)
I can do it for you if you want, but like I said it's easy.
ive done that m8 thanks....but still get error code 104 wrong bootloader when trying to downgrade firmware any ideas ??
regards will
Hmm, I searched around a bit on the XDA forums and the only thing I found was that trying different RUUs might help. This thread has a couple of alternatives (You'll have to scroll quite far down to the goldcard section of the first post). The unlockr page has an alternative RUU too.
It might be worth trying a different SD card if that doesn't work. The one that came with the phone worked for me.
ok m8 took the plunge and have managed to down grade to 2.73.405.5
im not sure but can i do the one click root method ??? im sure i read somewhere that i can
ok think it maybe rooted , ive done the flashrec and flashed recovery image and when i press home/power it gets me into a green menu in which i done a nand backup is this correct ?
also the main reason i want this is so i can install apps to sd card is this easy
