1. Get the extended battery (I got mine from Verizon for $24)
2. Get the Highest class Micro SD card you can afford - Speed is better than size!
3. Get the extended battery.![]()
alright guys i'm gonna get The esteem today. can you guys give me some tips for apps, battery life,etc.... Thanks![]()
As far as apps go, if you're on the 1 GB capped plan I'd suggest getting My Data Manager Free. It stays in your pulldown bar and keeps track of how much data you use.
that would be a waste of space concidering most data is not counted towards count. Only "streaming" and even then I have never gone over even though I use unearthly radio everyday.
