13 months of hard use and the battery in my Desire isn't working as hard as it used-to.
It makes a normal day - just - but if you play games or anything like that, you can almost see the battery meter going down...
Time for a replacement I reckon - but the really tricky part is finding a decent one - does anyone have a recommendation for a good supplier of honest/solid/decent batteries?
Is getting an 'original battery worthwhile - I've read a lot of the 'so called' high power batteries are actually worse than the original!?
Any experiences - any suppliers who've gone above and beyond for you??
