have you verified your browser is able to connect to the internet? Several things can cause this, including the phone having the wrong time/date.
Go to Settings > Date and Time > Make sure the date is correct, if not then set it to the correct date, and if you need to, time.
You can also go into settings > accounts >google > menu> remove, and re-add it and see if this resolves the issue
