DesireMe
Android Expert
So i've just figured out why it's good to have the contacts as google ones and what all this snyc'ing means.
All my contacts are google ones.
I can create or delete a contact from Gmail contacts using my computer and the change shows up in my Desire contacts.
If i delete or add a contact from the phone it is NOT changed in gmail on my computer.
I checked the sync settings and noticed something odd.
In Settings -> Accounts & Sync -> Google there is the list:
- Sync Contacts
- Sync GMail
- Sync Calendar
Each has a date and both Calendar and Gmail are up to date, but Contacts is 21st May 2010. Each account will sync, get a sync icon that disappears, and the date updates, all except on the contacts.
The only relevant searches i've found mentioned doing a factory reset.
Now having customized the phone for nearly 1.5yrs, i'd obviously like to avoid that.
- Sync Contacts
- Sync GMail
- Sync Calendar
