Help Google images problem?
Jerethi
Member
I'm experiencing an odd issue when browsing images using Google image search. A while back Google updated their image search for mobile devices; the images display against a black background, and you can switch between the images by swiping. However, when I do a Google image search and tap on an image, the image displays against the black background as it should, however, the image seems to get "stuck" and I can't initially browse by swiping. I can get it "unstuck" by clicking menu and then I seem to be able to browse by swiping, but it is very annoying that I have to go through these process in order to browse the images with swiping.
I checked this one a Moto Droid and it seemed to work well, which lead me to believe that it is a Droid Incredible issue. Has anyone else experienced this issue? If so, have you been able to fix it? Maybe it has something to do with the latest OTA update?
Any help is appreciated. Thanks!
