Help Google Maps and GPS Navigation Issues!!!
Ok I rooted my phone with Unrevoked3 the Unrevoked Forever. I used my GPS and Navigation to a friends house. It worked great! Then I flashed to the OTA official ROM. Didnt change any setting. My GPS is set on. Under the "LOCATION" setting..everything is checked.
Now I can go to Google Maps and then get my location and then search and stuff. I can even get direction to places. However, when I hit NAVIGATE...all I get is "SEARCHING FOR GPS..." And it would be stuck at the screen for the longest time without going into the Turn-by-turn direction. I turned off my GPS and turned it backed on again...NOTHING! I just adjust the setting...nothing. I even factory reset the phone and getting the same message when I use the navigation feature.
I also notice that the GPS location is not accurate at all...a lot worst than before. This is very annoying since I can use my turn by turn direction. I tried uninstall but the phone wouldnt let me. Since im rooted is there anything I can do?
I am having the exact same problem... I am rooted with Virtuous 2.6. I had these problems with SR 3.1, did a factory reset, reinstalled SR 3.1 and still had the problems. I thought it was a SR thing, so I put Virtuous on, and am still having these problems.
Some people have recommended going to settings > applications > development > make sure allow mock locations is unchecked. Maybe that will work for you, but it didn't for me.
