Root google maps battery assasin?
ok maps wasnt under battery use
i open it and right away its 10% wth???? come on guys it takes 5 secs to check this. do you or do you not have this problem and are u on stock or on blitzkrieg??
ok try this. does it do it when theres no trip cached? it seems it only kills the battery when theres a trip cached. not sure yet
for some reason wiping data for maps dalvik cash and all that good stuff then nandroid and factory reset then restore fixed it and its not hogging data anymore. significant use when i plan a trip but not in the background. wierd
