I had to use it to find the bar last night and for the 45 mins the gps took to find it it must have used at least 20% off battery..is this right??
You don't need Tasker to turn the GPS on when required - I leave my GPS enabled at all times, but it only switches on when an app needs it.
The Easiest way around this is to get yourself an in-car charger just like your standard SAT-NAV's which are
