The Motorla Moto G is my first smartphone.
I've never had satnav in my car so using Google maps for directions is new to me.
How do I use Google maps:
What do I need to turn on to get it to work: 'Data'/'GPS' or does it use the phone signal?
What is 'GPS' used for?
Anything else I should know.
If someone could explain as simply as possible that would be great.
Thanks
Thanks
) as you go. If you know where you are going beforehand you can, before you leave, use wifi or data to download the maps to your phone and then navigate without using data all the time. This is good if your route goes where there is no data or you are abroad and data would cost a lot.
