Help Google maps not not zooming in enough.
elcameano
I use google maps alot for my job and with the last 2 update I now cant zoom in enough see name of most roads.
This is as far as I can zoom in...anyone else notice this?
Have you tried uninstalling and reinstalling the updates or google maps itself? I was able to zoom in your location just fine and i notice your zoom button is grayed out too.
How do you uninstall updates? And I'm not rooted so dont think i can uninstall the app to try the reinstall....
go to market.android.com and force it to reinstall even though you have the latest updates. itll say its installed buy just tell it to send the file anyway and that should reinstall.
Terrain only zooms in so far. Turn off that layer.
I tried turning off the Terrain first but still wouldn't zoom in far enough. So I did the update uninstall and that did the trick.
EDIT: reinstalled it and can zoom in as needed!! Thanks Guys!
