Help Google Maps Zoom in Problem
ANM8
Hi, When using Google maps to zoom in on a road I can only partly zoom in, I used to be able to zoom right in on a road but now I can`t, :confused: Any ideas..?? Cheers.
Are you waiting long enough for the more detailed map segment to load? Maybe your data connection is off? Just a thought ....
Dave
Hi Dave, i`m sure it`s not a connection problem, its the same when using wireless, my mates desire zooms right in to the road where as my HD can only get as close as say the Village..!!!
