When I'm using google nav in the car, and plugged into car charger, the battery doesnt charge. Is there a way to fix this? I rememer having the same issue with the Inc. Is it a GB issue? Thanks!
It shows it's charging, but when I unplug it the battery level is usally pretty low. Even if I start with a full charge
I noticed this with my Droid phones too. I always thought it was because Nav is so battery intensive that it was draining as much battery as it was charging.
Sweet thanks, I'll grab a motorola next time I'm out. I am assuming 1 for the bionic will do the job?
Power mode is on normal, I'll have to check on the temp of the battery next time I use it.Another thing to consider is what setting you have your power settings, Settings>Power>Power Mode.
You have to use a HTC car charger (e.g. CC200). It charge the phone enough like the wall charger which came with phone.
EDIT: Look at the charging mode of your phone (Settings, About phone, Battery, Battery status):
"Charging AC", the charging of your wall charger.
"Charging USB", the charging of your current (generic) car charger.
This is not enough, the HTC car charger charges with "AC".
Harry
... 1. AC charger connect to car dock: 30 min run time, charage went from
100% to 92%....
With case 1. did you look at the phone's charging status (as I wrote above) and saw "Charging (AC)" ?
I think, your car dock doesn't use the data pins of its microUSB plug.
So the phone can't "see" the shortend data pins of AC charger.
And this shortend data pins are the "code" for phone to charge with "Charging (AC)".
Harry
Yes. Ac charging. I think the store got a bad batch or my phone has a problem. This only happens on the car dock. The desktop dock does not have the same problem.
+1 one to heat being a factor. I used to drive around with the AC wide open in defrost mode just to keep my DX running cool while using it as a NAV so it would continue to charge.
